I have 100's of images with the following format:
I want to populate an exif field in the image eg Description with the last part of the filename for example:
Description = Photo description 1
I want to perform the above for all files in a folder (batch add metadata based on part of the filename)
The batch logic would be = look at the filename starting from the right, look back through the characters until find '_' take the filename from the right of the '_' and populate the description exif field.
Is this possible if so please can someone shed some light on how to do it.
Cheers
Batch add exif metadata from actual name of file....
