Well, first try of XnViewMP on my Linux MdV
Pierre Pallier
Post by Pierre Pallier »
Hi there,
Well, it works ! :)
It is working fine, and really faster than Gwenview, for example.
Thanks to the author(s).
Here are some unsorted things (sorry for my English language) :
- Mouse wheel : rotation seems to be inverted. When I want to go forward in pictures, I go backward.
- I should really appreciate a feature like this : switch between 100% zoom and automatic zoom with a single wheel click. In all viewing modes.
- Histogram and Info (in full screen mode) settings seems not to be saved all time. I must sometimes type "H" and "I" again when restarting XnViewMP.
- I can't drag and drop files from thumbnails pane to directories pane, I can only drag and drop in thumbnails pane.
- There are some crashes, but I can't really reproduce them. Sometimes, it crashes when I'm clicking on a thumbnail.
Well, it's what I can say this evening...
And congratulations for this good test-release !
Pierre
Re: Well, first try of XnViewMP on my Linux MdV
Pierre Pallier wrote: - Mouse wheel : rotation seems to be inverted. When I want to go forward in pictures, I go backward.
Known issue
You can't reproduce :-( Not on some format like pdf?
Pierre Pallier
xnview wrote:You can't reproduce :-( Not on some format like pdf?
I'll try, I'll try to reproduce it... :)
(No PDF, I clicked on some jpg)
Pierre
Pierre Pallier
Here is a copy of terminal window, after a crash occured after change of thumbails size, in explorer mode. (I shortened paths, and copy only the end of the output listing)
[EDIT] : Oops, files names are gone after sending.
Well, errors occured after pdf files, but segmentation fault was after loading a jpg file. Sorry for this bad report.
Au cas où, une copie de ma console suite à un crash survenu après avoir changé la taille des vignettes avec le curseur ad-hoc, en mode explorateur (j'ai raccourci les chemins et n'ai placé que la fin de la sortie sur console)
- - - - - 8< - - - - - - - -
LOAD BITMAP </media>
GFF :: LoadThumbnail : 0
LOADED & CREATED
LOAD BITMAP <//media/hd/Docs_Divers/economies_d'energie.xls>
GFF :: LoadThumbnail : 2
Error: /undefinedfilename in (and)
Operand stack:
Execution stack:
%interp_exit .runexec2 --nostringval-- --nostringval-- --nostringval-- 2 %stopped_push --nostringval-- --nostringval-- --nostringval-- false 1 %stopped_push
Dictionary stack:
--dict:1144/1684(ro)(G)-- --dict:0/20(G)-- --dict:70/200(L)--
Current allocation mode is local
Last OS error: 2
GPL Ghostscript 8.60: Unrecoverable error, exit code 1
Operand stack:
Execution stack:
Dictionary stack:
Last OS error: 2
LOADED & CREATED
Operand stack:
Execution stack:
Dictionary stack:
Last OS error: 2
xnview.sh: line 4: 22539 Erreur de segmentation ./xnview
HTH.
Pierre
L'erreur provient peu etre du slider pour modifier la taille vignette... Essayez sans?
Pierre Pallier
Je vais m'abstenir en effet, pour moi il y a un soucis avec le "Slider".
Ce n'est pas systématique, mais je viens de le planter à deux reprises avec une erreur de segmentation.
Pierre
Pierre Pallier wrote:Ce n'est pas systématique, mais je viens de le planter à deux reprises avec une erreur de segmentation.
Avec le slider?
Pierre Pallier
xnview wrote:Avec le slider?
Oui, pardon, je me suis mal exprimé. Je bouge le slider, ça change la taille, et pendant que ça recalcule les thumbnails, hop, ça plante. Parfois. Deux fois sur dix, en gros, chez moi.
Quand ça ne plante pas, j'ai remarqué que ça passe en affichage "Vignettes+Libellés" alors que la case "Vignettes" est toujours cochée dans la liste de choix accessible via l'icone "Voir en".
Pierre
Je vais regarder de plus près, j'ai eu qq crash avec le slider...
bernard decock
Crash
Post by bernard decock »
J'ai encontré quelque chose pareil (Voir http://newsgroup.xnview.com/viewtopic.php?t=16722). Sorry for my bad french :wink:
