Don't open images maximised
Ben
Post by Ben »
Hi all
Just coming from using Paintshop Pro as an image browser and started using XnView - overall I love it. One issue is really driving me nuts though, and I can't seem to find the solution on the forums...
I use dual monitors and have the browser as a floating window on the left monitor; I need to compare images side-by-side so would like to have them open in floating windows when I click a thumbnail. Currently they each open maximised, filling the whole 2 monitors, so I have to click restore, then manually resize the window, which is a bit too long-winded when there are lots of files to go through.
So - is there any way to have images open in a floating window, and not maximised??
Thanks in advance!
Ben
siepict
two instances
Post by siepict »
Hi Ben,
I use dual monitors
same with me. I'm opening two instances of XnView
1. thumbs on the left and full display on the right monitor
2. vice versa
horst
Post by Guest »
Ha - nice trick. Thanks for the tip horst, works well to get around a simple shortcoming (if coming from Photoshop or Paintshop Pro) with the program.
Fingers crossed the developers consider introducing basic Photoshop/PSP-style window handling in a version soon.
Re: Don't open images maximised
Why not to use 'compare picture'?
pic_viewer
Post by pic_viewer »
xnview wrote:Why not to use 'compare picture'?
Why does it always open a full screen window, even if I had changed the window size and closed it then?
You talk about the MDI child window, and not the main window, right?
siepict
Post by siepict »
That is a fine option, but you may not scroll to the next picture:
As long as the 'compare window' is opend, you don't have any access to the main window (the browser) of XnView
horst
pic_viewer
I am talking about the 'Compare Picture' window - maybe that is an MDI window, don't know.
