Resize: changing Units doesn't change Print Size
dee
Post by dee »
In Resize dialog, uncheck Keep Print Size and change Units number.
What happens: Screen Size changes.
What I expected: Print Size change.
Why I expected it: at the moment, Keep Print Size checkbox has no effect, it always keeps print size. Opposite of keep print size is probably change print size.
Version:
XnView 1.95.4 freshly unpacked from zip, with old config deleted, so everything is reset at defaults (XnView automatically opened initial config dialog).
Please refer to this discussion for suggested improvements: Change of DPI (Set DPI vs. Resize)
