K10D pef and E420 orf incorrect white balance
darrask
Post by darrask »
concerning the K10D pef:
same color when opening the file.
the file is here:
http://www.divshare.com/download/6157232-4f1
as for the E420, same problem, though less visible, here is the file:
https://share.acrobat.com/adc/document. ... d9240ad6ce
It is worse in dim light.
Re: K10D pef and E420 orf incorrect white balance
With 1.95.4? Which settings do you have for 'read/camera raw'?
darrask
Post by darrask »
Hello Pierre.
Yes, sorry I forgot:
last version 1.95.4, settings:
No problems with other RAWs from other manufacturers.
Ok, for the pef, if you use 'camera white balance', there is a problem
darrask
Post by darrask »
It's the same for the E420, you see it better in night shots:
The point is, for the E420, I did not have these problems in previous versions, though I can't remember exactly which ones.
I send you this ORF sample by mail.
