Thumbnails for Adobe Illustrator .ai files?
ghost zero
Post by ghost zero »
How about show thumbnails for Adobe Illustrator .ai files?
Re: Thumbnails for Adobe Illustrator .ai files?
ghost zero wrote:How about show thumbnails for Adobe Illustrator .ai files?
Do you have AFPL ghostscript?
ghost zero
what is that?
ghost zero
I believe Adobe Illustrator .ai files have embedded thumbnails. Can those be read?
asibug
Post by asibug »
this one would be cool and if ever add coreldraw files as well if possible. :)
"The Difference Between Impossibilities and Possibilities is Creativity."
ghost zero wrote:I believe Adobe Illustrator .ai files have embedded thumbnails. Can those be read?
Yes, XnView can read these thumbnails. But remember: Not all AI, EPS or CDR files have previews embedded in them. It depends on the program they were saved with/exported from and on the settings made by the file's author.
Forum references:Off-site resources:
Adobe Illustrator File Format Specification wrote:%AI3_DocumentPreview: keyword
  • [ 3.0/3.2 ] [ 5.0/5.5 ] [ 6.0 ] The %AI3_DocumentPreview comment describes the type of preview image contained in the file. If no preview is included, keyword is None.
FAIK XnView reads .ai files using Ghostscript and builds the thumbnail based on the vector image. I doubt that XnView reads the embedded thumbnail. @Pierre: Please shed some light on this.
For Corel files (.cdr, .cps, ...) the answer is clear: Image is not read, only embededded "thumbnails" are displayed, XnView cannot read the Corel format because it's a proprietary and closed format. See topic Handling limited Corel format support.
ghost zero
thumbnails for .ai files are displayable in Adobe Bridge file browser, so i was wondering if that was possible in xnview
I don't have GhostScript installed on my Windows 2000 PC. XnView behaves exactly as I want it to:
  • For AI files without an embedded document preview, XnView displayes the system's file type icon.
  • If an AI file contains an embedded document preview, XnView extracts it and uses it as thumbnail in the browser and for the preview pane (even if %AI3_DocumentPreview: None).
Other than with EXIF thumbnails in JPEGs, embedded previews in AIs are located at the end (after %%EOF) of the file and are either in TIFF (PC) or PICT (Mac) format.
XnTriq wrote:... [*]If an AI file contains an embedded document preview, XnView extracts it and uses it as thumbnail in the browser and for the preview pane (even if %AI3_DocumentPreview: None). ...
Ah, o.k.. This prooves that XnView does read the embedded thumbnail in ai files.
