Nikon D90 EXIF Makernotes incorrect in lens fields
ohdeeremee
Post by ohdeeremee »
1.95.4 shows incorrect data in Makernotes for Nikon D90 for the lens.
LensID : 32 18 122 40.3 3.6
Lens ID Number : 122
Lens FStops : 11.58
Minimal Focal Length : 32.0 mm
Maximum Focal Length : 18.0 mm
Max Aperture at Minimal Focal : F40.3
Max Aperture at Maximum Focal : F3.6
MCU Version : 60
I assume this is not what it should look like.
For the Nikon D80, the information looks correct.
LensID : 18 200 139 3.6 5.7
Lens ID Number : 139
Lens FStops : 5.33
Minimal Focal Length : 18.0 mm
Maximum Focal Length : 200.0 mm
Max Aperture at Minimal Focal : F3.6
Max Aperture at Maximum Focal : F5.7
MCU Version : 253
Both of the above is for Lens: VR 18-200mm F/3.5-5.6G
This appears to be incorrectly translated from the fields.
XnView for D90 does not show any lens (3 tried) correctly.
I have XnView, Nikon ViewNX, and Exiftool outputs, and a compressed version of the input photos ready to send to someone, just let me know where. About 350KB for the 3 different photos and 9 sample outputs.
Thanks, G
Re: Nikon D90 EXIF Makernotes incorrect in lens fields
Could you send me a sample?
ohdeeremee wrote:I have XnView, Nikon ViewNX, and Exiftool outputs, and a compressed version of the input photos ready to send to someone, just let me know where. About 350KB for the 3 different photos and 9 sample outputs.
FAQ: How to contact the author
ohdeeremee
Sent info per your request, 16 files, about 500KB to Contact on 12/27
Thanks
Luca
Post by Luca »
I'm using the last version (1.96) and the problem is still there. Do you think to correct it?
Thanks a lot for your great job!
Luca
Luca wrote:I'm using the last version (1.96) and the problem is still there. Do you think to correct it?
Yes, but not easy to fix
