TWAIN scanner problem
Lior
Post by Lior »
I've recently purchased a canon scanner-printer all in one to replace an older mustek scanner. Scanning via the TWAIN driver fails. This is also the case when using IrfanView, however it works fine with GIMP. Suggestions anyone?
Thanks,
Lior.
Re: TWAIN scanner problem
Try the WIA import
Post by Guest »
The WIA import produces poor quality. Any suggestions regarding using the TWAIN?
Anonymous wrote:The WIA import produces poor quality. Any suggestions regarding using the TWAIN?
Do you have a TWAIN driver??
