no batch conversion
no batch conversion
Post by Guest »
I tried to use the batch conversion, but there is no batch conversion under "tools". I can only export files, that's all and only one file at a time and not all together.
I'm using:
XnView QT
Version 0.12 (Nov 19 2008) Libformat version 5.06
You are using XnView MP which is under development and which hasn't got the Batch functionality, yet. You have to use XnView Windows or XnView for Un*x. (Not 100% sure that XnView Un*x does support it).
Post by Guest »
Thanks for the answer, but I'm using a mac and it seems that there is no version for a mac which is able to convert files by batch mode.
Burkhard
