XnView crash if folder with a lot of file
hispanico
Post by hispanico »
I have windows vista 32bit. No problem using XnView but i have a big folder with 5.000 file image (jpg, bmp) and i search to view the folder inside XnView the program after a while crash, also if i try to rebuild cache: i select the folder, xnview search to build the cache and when arrivong to 20% the program go in crash again......
While if i made the same procedure in folder with 200 image file or 1.000 no problem....
In which way i can solve ?
Thank
ckit
Post by ckit »
Try disabling Read Ahead Cache
Re: XnView crash if folder with a lot of file
Perhaps a problem with a file?? Do you have only picture files?
hispanico
Post by hispanico »
ckit wrote:Try disabling Read Ahead Cache
Yes i have only pictures jpg or bmp... I want try to disabling Read Ahead Cache but where is this option ..i see only caching yes/no...
I try to disabling cache and the problem not more appear ! So the problem is the cache system....i wich way i can try to solve this ?
Thank
ckit
Post by ckit »
In Options -> View -> Misc. -> Cache (disable both items here)
hispanico
Post by hispanico »
ckit wrote:In Options -> View -> Misc. -> Cache (disable both items here)
Thank i find it....but the problem remain...
The crash occurs always on same file?
hispanico
Post by hispanico »
No sometime after 1 minute or after 3 minute while xnview scan the folder...
All RAM is not used?
hispanico
Post by hispanico »
I have windows vista 32bit and 4GB of memory and when use XnView for scaan folder only 1GB is used.
Thank
hispanico wrote:
xnview wrote:
hispanico wrote:No sometime after 1 minute or after 3 minute while xnview scan the folder...
Could you try to diabled option/Thumbnails/Cache
Kuro Neko
Post by Kuro Neko »
xnview wrote:
hispanico wrote:
xnview wrote: All RAM is not used?
I have the same problem, and that not solve the problem. :'(
All cache features are disabled and problem remais...
Lot images in folder.
That not occurs if you "explore with xnview" the folder and view all the files... why only in "View Mode"?
Kuro Neko wrote: That not occurs if you "explore with xnview" the folder and view all the files... why only in "View Mode"?
The crash is not in browser mode? You have it when you select a file to view?
Kuro Neko
Post by Kuro Neko »
Yes, this only occurs when i open a image (in a folder with a lot of images, especially wallpapers 300 or more) directly (double click from windows xp) and attemp to change to next or previous image, it takes a long time... (1 - 2 minutes) only one time, the next changes are inmediatly.
Sorry for my poor english, i am a spanish speaker. ^_^
CPU: Dual Core 2 Duo 2.2 GHz
RAM: 2 GB
AGP: Nvidia 512 MB
SO: Win XP SP3
Which sort do you have in browser?
