Why new sizes are less than original?
durumdara
Post by durumdara »
Hi!
I have many new images that I converted with nconvert.
The sizes, and all other jpg properties are same. The quality is 100%.
For example:
"C:\Program Files\XnView\nconvert.exe" -out jpeg -o "C:\Dev\XNViewConverter\testdir\__processed__\dalai-lama.org.jpg" "C:\Dev\XNViewConverter\testdir\dalai-lama.jpg"
"C:\Program Files\XnView\nconvert.exe" -ctype grey -corder inter -out jpeg -grey 256 -o "C:\Dev\XNViewConverter\testdir\__processed__\dalai-lama.baw.jpg" "C:\Dev\XNViewConverter\testdir\dalai-lama.jpg"
"C:\Program Files\XnView\nconvert.exe" -autocontrast -out jpeg -o "C:\Dev\XNViewConverter\testdir\__processed__\dalai-lama.cnt.jpg" "C:\Dev\XNViewConverter\testdir\dalai-lama.jpg"
"C:\Program Files\XnView\nconvert.exe" -autolevels -out jpeg -o "C:\Dev\XNViewConverter\testdir\__processed__\dalai-lama.lev.jpg" "C:\Dev\XNViewConverter\testdir\dalai-lama.jpg"
"C:\Program Files\XnView\nconvert.exe" -normalize -out jpeg -o "C:\Dev\XNViewConverter\testdir\__processed__\dalai-lama.nrm.jpg" "C:\Dev\XNViewConverter\testdir\dalai-lama.jpg"
"C:\Program Files\XnView\nconvert.exe" -equalize -out jpeg -o "C:\Dev\XNViewConverter\testdir\__processed__\dalai-lama.equ.jpg" "C:\Dev\XNViewConverter\testdir\dalai-lama.jpg"
"C:\Program Files\XnView\nconvert.exe" -log -out jpeg -o "C:\Dev\XNViewConverter\testdir\__processed__\dalai-lama.log.jpg" "C:\Dev\XNViewConverter\testdir\dalai-lama.jpg"
The input file size is 100000 byte, the output is 29-40K.
Or another original image size is 493K, the output is 115K.
What I do wrong?
Thanks for your help:
dd
Re: Why new sizes are less than original?
durumdara wrote: The input file size is 100000 byte, the output is 29-40K.
What I do wrong?
You can control quality with -q
durumdara
Post by durumdara »
What I do wrong?
That was!!! Thanks!
Interesting, because the help said that -q 100 default.
But if I forget to set it to 100, I got another result... Hmmmmm...
Possible that help is wrong in this param?
Thanks for it, but please help me a little: what is PCD???
Sorry, but I don't know...
dd
durumdara wrote: Thanks for it, but please help me a little: what is PCD???
It's a format from kodak
