One of the Batch Processing format options is "TIF - TIFF Revision <b>6</b>".
When checking the output with JHOVE the file is reported to be "Status: Well-Formed and valid" (good), but "Version: <b>5</b>.0" (which is not what I had hoped).
XnView 1.95.4
Windows 2000
"TIFF Revision 6" produces a TIFF version 5.0 file
Roadkill
Re: "TIFF Revision 6" produces a TIFF version 5.0
It's really a TIFF v6 that xnview write
Roadkill
Thanks for the reply.
There must be some reason why the "JSTOR/Harvard Object Validation Environment" reports it as a version 5.0 TIFF. I don't understand much of the information, but perhaps you do: JHOVE TIFF-hul Module.
