hallo,
I found this on
http://www.iptc.org/cms/site/photometad ... =CH0101#17
XnView
Product version 1.82.4
Supports XMP and IPTC Core --> None of them
Supports IPTC Extension --> NO
Synchronizes IIM/Core values --> Metadata values are synchronized: - no
Information provided by the vendor on 2006-11-11
Are these data correct?
Oliver
IPTC Extension
Peter2
Maybe - in the good old times (2006).wolli wrote:...Are these data correct?...
That is the problem. Now we have 01-2009 with version 1.96 beta - and a lot of additional IPTC, XMP and other metadata support. Take a look at it!wolli wrote:...Information provided by the vendor on 2006-11-11...
Regards
Peter
- Forum Librarian
Thank you for the hint, wolli
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=69192#69192]Recherche IPTC core et référencement internet[/url]) wrote:Ok, merci, je vais essayer de les contacter
Re: IPTC Extension
XnView support IPTC core as reading & writing, and can convert IPTC=>XMP or XMP=>IPTC
