v.012 Windows: [sugg.] Search dialogue - more queries
Peter2
Post by Peter2 »
The queries in the search dialogue should be extended so that any query has also its "opposite (example: MS Excel)
is / is not
contains
/ contains not
start with / starts not with
ends with / ends not with
Regards
Peter
+1 (Over the years even private people gather thousands of images on their computer, so image management and an effective search is more and more important).
oops66
Re: v.012 Windows: [sugg.] Search dialogue - more queries
Post by oops66 »
Plus in advanced search, for IPTC Keyword, it's better to have by default "contains" instead "is".
And if I use: "data base is checked" and "Recurse throw subfolders is checked too", the result can be blank (if keywords havn't been collected yet into the Data Base).
In this case, "if data base is checked", I think it's better to collect first all IPTC keywords from subfoldres to the Data Base, or at least have a message box " Do you want to collect all related IPTC keywords from these subfolders to the DB ? ".
Rename request:
Match all of these following conditions --rename to--> Match all conditions (AND)
Match any of these following conditions --rename to--> Match any conditions (OR)
See here: http://newsgroup.xnview.com/viewtopic.php?p=70601#70601
