.fit file will not open
Dashwsk
Post by Dashwsk »
I downloaded XnView to view some .fit files. I saw on ur homepage that .fit was supported, but when I tried to open it in the program it would not work.
I then checked supported formats in the XnView program itself and .fit was not listed.
Does it open .fit files or not? and if so, then how?
helmut (FAQ: [url=http://newsgroup.xnview.com/viewtopic.php?p=56845#56845]Does XnView support graphic format .xyz?[/url]) wrote:
marsh wrote:When trying Xnview, note the following option:
  • General>Startup>[ ]Use all formats available
Activating the above checkbox is really essential for those people who want to see and use all formats supported by XnView. In XnView 1.92 the checkbox is labelled "Display all image file types".
