Unable to convert .bmp or .jpg to tif
MichaelW13
Post by MichaelW13 »
Hi
When I try convert .bmp or .jpg to the tiff file format, nconvert outputs a tif file and gives no errors. When I try and open the file in Windows Imaging I am given the error message 'The documents format is invalid or not supported' with the jpg and 'An internal error has occurred' with the bmp. I am using the command
The results are the same wether I use compression or not as well as when specifying the input type or not. Is there anything wrong with my method or is there something I need to know about converting from jpg and bmp to tiff?
Thanks
Michael
Re: Unable to convert .bmp or .jpg to tif
MichaelW13 wrote:When I try convert .bmp or .jpg to the tiff file format, nconvert outputs a tif file and gives no errors. When I try and open the file in Windows Imaging I am given the error message 'The documents format is invalid or not supported' with the jpg and 'An internal error has occurred' with the bmp. I am using the command
Strange, which version do you use?
