Iconset for XnView 1.75
The current iconset provided in XnView 1.74 has some problems/issues:
- Transparency not correct (see topic 'Filetype icons: Wrong transparency'
- In detail view, 16x16 pixel icons do not look nice
A while back, Carlos Duarte has provided a new iconset, see topic 'Special icons developed exclusively for XnView'. Carlos' iconset has some new problems (including possible copyright issues, the small icons look much like ACDSee icons).
So I've decided to do some design work. The result is another iconset. The iconset contains icons for various graphic formats in
- 16x16
- 32x32
- 48x48 pixel
The 16x16 pixel icon all look the same for all formats (JPG, TIF, ...), so the format cannot be seen when looking at the icon (different to ACDSee). The 16x16 pixel icons are used in detail view of MS Explorer for example, in this view one can see the file type in a column, which I find sufficient. Please holler if you think it's important to see the format info in the small icons, too.
I'm not a graphic designer, perhaps some people can have a look and check whether
- Icons look o.k. both in "Symbol" and "Details" view of MS Explorer.
- Icons look o.k. on a PC with limited colours (256, 65536)
Also any other feedback is welcome.
- 16x16
- 32x32
- 48x48 pixel
Dreamer
Re: Iconset for XnView 1.75
I think it is important - especially in every file manager (I can't live without it anymorehelmut wrote:Please holler if you think it's important to see the format info in the small icons, too.
Also the "right" colors would be nice - BMP, JPG, GIF ...
Here are some ideas how it could looks - BMP1, BMP2, BMP3, BMP4- it's not the final look, it's just the concept.
Better ideas are welcomed!
Dreamer,
thank you for your feedback and your draft icon.
As written above the format cannot be seen in the 16x16 pixel size, only. In the other sizes the format can be seen.
In the current iconset of XnView 1.74, one cannot read the format info at all, it's too tiny when viewing in detail view of MS Explorer. So I wonder which icons you use at the moment?Dreamer wrote:I think it is important - especially in every file manager (I can't live without it anymorehelmut wrote:Please holler if you think it's important to see the format info in the small icons, too.
What do you mean with "right" colours? The XnView browser uses colours for various format which could be used for the icons, too. But these colours are not part of the standard palette, so on computers with less colours available this might not look very nice or there might be no difference at all.Dreamer wrote:Also the "right" colors would be nice - BMP, JPG, GIF ...
ckv
Nice icons helmut
Nicely done helmut I like the especially the 16 x 16 icons
but Dreamer haves also good idea and good looking icons. Maybe its time to create completely new icons for XnView
Dreamer
Same as "detail view of MS Explorer"helmut wrote:In the current iconset of XnView 1.74, one cannot read the format info at all, it's too tiny when viewing in detail view of MS Explorer. So I wonder which icons you use at the moment?Dreamer wrote:I think it is important - especially in every file manager (I can't live without it anymorehelmut wrote:Please holler if you think it's important to see the format info in the small icons, too.
I know, your icons are very nice, but I think it's still not enough - especially in the higher resolutions (e.g. LCD - 1280x1024, I want to buy one soon)helmut wrote:As written above the format cannot be seen in the 16x16 pixel size, only. In the other sizes the format can be seen.
I think it's not a big problem today (for most of XnView users)...helmut wrote:What do you mean with "right" colours? The XnView browser uses colours for various format which could be used for the icons, too. But these colours are not part of the standard palette, so on computers with less colours available this might not look very nice or there might be no difference at all.Dreamer wrote:Also the "right" colors would be nice - BMP, JPG, GIF ...
That users don't have the right colors also in XnView (browser) or do they? I'm not sure what you meant, could you explain please?
Also you could use the 'standard' (near) colors or not? How it is in ACDSee?
Another solution could be an option "Use single icon for all file types"
Olivier_G
Why not? Most letters can probably be drawned within 5x5 pixels or even 5x4, which would be enough for 3 letters in the 16x16 icons.helmut wrote:The 16x16 pixel icon all look the same for all formats (JPG, TIF, ...), so the format cannot be seen when looking at the icon (different to ACDSee).
I personnaly have never showed the 'type' column for... er... 6 years, to save screen space, therefore the icon in the detailled view is extremely convenient. I also believe that some standards Colors (depending on filetype) would help to handle quickly them as well.
Olivier
ckit
These icons look ok but you need a different background colour in the box around the filename extension. The same method as IrfanView except the overall design is still different.
Dreamer
Dreamer,
Dreamer, could you please be a bit more precise in your reply? I really liked to understand what you mean.
Greetings,
Helmut
I don't understand: If you use the standard icons of XnView 1.74, you will not be able to see the format?Dreamer wrote:Same as "detail view of MS Explorer"helmut wrote:In the current iconset of XnView 1.74, one cannot read the format info at all, it's too tiny when viewing in detail view of MS Explorer. So I wonder which icons you use at the moment?
"still not enough" - not enough of what?Dreamer wrote:I know, your icons are very nice, but I think it's still not enough - especially in the higher resolutions (e.g. LCD - 1280x1024, I want to buy one soon)helmut wrote:As written above the format cannot be seen in the 16x16 pixel size, only. In the other sizes the format can be seen.
Don't understand. You're answering my question with a question.Dreamer wrote:I think it's not a big problem today (for most of XnView users)...
What do you mean with standard colours? Which standard? ACDSee uses the 16 colours of the standard 16 colour map (yellow, red, blue, green, lightgreen, grey, lightgrey, ...). Have a look at the iconset provided by Carlos (see above), this is pretty much what ACDSee's 16x16 pixel icons look like.Dreamer wrote:Also you could use the 'standard' (near) colors or not? How it is in ACDSee?
Perhaps a way to solve the "problem", but before introducing another option we always should try to find a solution that is suitable for all people. If we don't find any we still can introduce an option.Dreamer wrote:Another solution could be an option "Use single icon for all file types"
Greetings,
Helmut
Re: Nice icons helmut
Hello ckv,
Actually, only the 16x16 icons are done by me. Not sure who designed the 32x32 and 48x48 ones. I've corrected the latter ones a bit, only.
Perhaps support for several iconsets is a good idea, but this will not happen in near future, I think.
thank you for the feedback.ckv wrote:Nicely done helmut I like the especially the 16 x 16 icons
As written before, I'm not a graphic designer. If someone reads this and wants to volunteer, please go for it.ckv wrote:... but Dreamer haves also good idea and good looking icons. Maybe its time to create completely new icons for XnView
Hello Olivier,
Please note that I'm not pro or con having various 16x16 icons. I'm just collecting good arguments for the one or the other to make a decision.
Yes, three leters fit into 16x16 (see iconset of Carlos). The question is whether the three letters are sufficient or whether colour is also needed for distinction.Olivier_G wrote:Why not? Most letters can probably be drawned within 5x5 pixels or even 5x4, which would be enough for 3 letters in the 16x16 icons.helmut wrote:The 16x16 pixel icon all look the same for all formats (JPG, TIF, ...), so the format cannot be seen when looking at the icon (different to ACDSee).
There's still the extension in the file name (assuming that you haven't activated the option "Hide file extension for known file types" in MS Explorer).Olivier_G wrote:I personnaly have never showed the 'type' column for... er... 6 years, to save screen space, therefore the icon in the detailled view is extremely convenient. I also believe that some standards Colors (depending on filetype) would help to handle quickly them as well.
We have several threads in this topic. So please try to be "extra clear" in your answers. This will make our life easier...Dreamer wrote:You're talking about my or Helmut's icons?ckit wrote:These icons look ok but you need a different background colour in the box around the filename extension. The same method as IrfanView except the overall design is still different.
Olivier_G
Helmut: please note that the iconset by Carlos cannot be downloaded anymore.helmut wrote:(see iconset of Carlos)
(link referred in the other thread: http://1337.radioglobal.org/xnicons/)
Olivier
Not found---
- The link above is dead : “404 Not found”, even removing the innoportune parenthesis at the end...
Olivier, Clo, et al,
didn't know that the link to Carlos' iconset was broken.
I've just uploaded Carlos' Iconset, again.
Greetings,
Helmut
Greetings,
Helmut
