strange blinking
invid4
strange blinking
Post by invid4 »
Hello
Since a few weeks (i don't know since when, maybe when upgrading to latest version ? Maybe something else...), when i browser a folder with several pictures (with the "show only images" filter enabled), i have a strange "blink", and i can't scroll down as the folder keeps going back to the "top" position...
I never experienced this bug before.
Re: strange blinking
It's the second pass to remove bad items
invid4
Post by invid4 »
Ok, so, by disabling the filter it should be ok, then ?
Bonjour, et merci pour la réponse (rapide !). Il suffirait donc d'enlever le filtre ?
invid4 wrote: Bonjour, et merci pour la réponse (rapide !). Il suffirait donc d'enlever le filtre ?
Oui ou de modifier option/Liste fichier
