BUGS:
Browser mode should display back to previous directory,as have been seen in V1.954,look like folder/drive icon+..!
After cropping image,pop up question dialog box to tip "do you want to overwrite it",default cursor is on "no", why not "yes" ,maybe that's to avoid misoperation,however,that's a bit wasting time.I advise this is optional in preference.
BTW,my english is poor!
Thank you for your consideration.I would look forward to your reply!
Thanks Pierre!
B2: Back to previous directory
yixunweilan
Fear Always Springs From Ignorance!
Re: B2-BUGS:Back to previous directory
How that? You can use back to go to previous folder...yixunweilan wrote: Browser mode should display back to previous directory,as have been seen in V1.954,look like folder/drive icon+..!
Yes, you can press enter too quicklyAfter cropping image,pop up question dialog box to tip "do you want to overwrite it",default cursor is on "no", why not "yes" ,maybe that's to avoid misoperation,however,that's a bit wasting time.I advise this is optional in preference.
yixunweilan
You mean backspace or up one level button,of course I know,but that's awkward!So,please!xnview wrote:How that? You can use back to go to previous folder...yixunweilan wrote: Browser mode should display back to previous directory,as have been seen in V1.954,look like folder/drive icon+..!Yes, you can press enter too quicklyAfter cropping image,pop up question dialog box to tip "do you want to overwrite it",default cursor is on "no", why not "yes" ,maybe that's to avoid misoperation,however,that's a bit wasting time.I advise this is optional in preference.
Aha,if so,then,maybe I will be hurry-scurry.Furthermore,in this beta2 version,I can not press enter at all!I can not move arrow cursor to"no"or"yes",untill I press options.You can try it again.
Sorry but i don't understand your problem?yixunweilan wrote: You mean backspace,of course I know,but that's awkward!So,please!
yixunweilan
I mean there is no ".." in browser mode!That is inconvenient!
Maybe I couldn't describe that correctly!Then so be it!
Sorry to bother you!
Thank you for your excellent software!
Tick the box
• Indeed there is ! Options (F12) >> Browser >> File List under >> Tick the box Parent folder (“..”)I mean there is no ".." in browser mode!That is inconvenient!…
yixunweilan
