Auto refresh,Cut,Copy,Shortcut keys,Auto rename.
yixunweilan
Post by yixunweilan »
PROPOSALS AND SUGGESTIONS:
1.After cutting a file in browser mode,sometimes it is unable to refresh automatically and immediately,improve it,please.
2.In viewer and fullscreen mode,it can not use CTRL+C/CTRL+X to copy or cut image file,improve it,please.
3.Display "file modified/changed date" on status bar,please.
4.Set Ctrl+H as shortcut key to toggle "show hidden files",please.
5.In browser mode,set F10 as shortcut key to toggle "view mode as list",please.
6.When copying same name file, just like ACDSee pop up a "confirm replace" dialog box,or auto rename,like *_2.
7.When batch rename,use the fist file's name as name template,please.
8.Auto overwrite "xnview_wallpaper.bmp",please.Don't log in XnView folder or optional in preference.
BTW,my english is poor!
Thank you for your consideration.I would look forward to your reply!
Thanks!
Fear Always Springs From Ignorance!
yixunweilan
Re: SUGGESTIONS:Auto refresh,Cut,Copy,Shortcut keys,Auto rename.
:arrow: yixunweilan
:) Hello !
• Well, according to the forum rules, you must post one topic-suggestion per thread…
• So, I would advise you to check via the Search (sometimes, it works… :P ) whether each topic you presented above
is not there already, or added¦fixed in the meantime…
- Sorry for the unanswering, but that isn't amazing from such a multi-request… :|
:mrgreen: Kind regards,
