Raw-Conversion doesn't seem to work
Fraenzken2
Post by Fraenzken2 »
I've just discovered that if I try to batch convert Raw-files (tried with files from the Olympus E-30 and the Olympus E-510), the output file is only half the size of the original raw. Also, colours are completely (not only slightly, that's normal) different from the ones in the corresponding jpgs. Is it a bug, or do I do something wrong? By the way, Camera Raw size is set to "full size".
Best wishes
Frank
Re: Raw-Conversion doesn't seem to work
There is a problem in current version for RAW files
Fraenzken2
o.k., thanks!
kikobono
Post by kikobono »
Hello.
Has this been fixed?
Or is there any workaround for batch converting LOTS of raw in jpg?
kikobono wrote:Has this been fixed?
yes
kikobono
Post by kikobono »
It does seems to work on my XnView 1.97.4 on XP-SP2
I just try to convert a bunch of raw (from .MRW to JPG) and it resizes all the images from 3016x2008px to 1508to1004px.
Enrico
Do you have enabled option/read-write/read/RAW>High resolution?
kikobono
Post by kikobono »
Errrr....
Sure I have ;)
Now it works, I didn't know about this option and didn't found anything con the forum.
Thanks,
Enrico
