Support for C4 format - Jedmics/Edmics Cals Raster
w8asa
The website seems to indicate support for this format, but the program itself doesn't recognize the files. Are there any plans to support this format? Or, am I doing something wrong. If you want, I can send you an example file or files. Merci beaucoup.
Reading only
• The C4 Edmics format is supported at reading only.
- Whether the pics aren't displayed¦recognized, please verify if the box :
Options (F12) >> General >> [×] Display all image file types is ticked !
• In addition, you could set the C4 extension onto the File List box, like explained HERE (use the “Include” field).
