Thumbnails do not appear (bug)
Legnani
Post by Legnani »
when using the command "create html page" Thumbnails sometimes do not appears
The tumb.html file contains errors because the link is wrong
XnView creates links like this
src="thumb\t_P1040566.jpg"
while the correct string is
src="thumb/t_P1040566.jpg"
you need a slash (not a back-Slash)
In my case pages are displayed correctly if I use Expoler, but the thumbnalis do not appear if I use MozillaFirefox. The html pages are on a unix server.
I generally correct "by hand" all the pages generated by XnView. It is possible ti fix this bug?
Re: Thumbnails do not appear (bug)
Which version do you use? I have the good '/' in created html files
Legnani
Post by Legnani »
xnview wrote:Which version do you use? I have the good '/' in created html files
my version is 1.91 - 16 MAY 2007
and your?
Legnani wrote:and your?
1.95 is available
