Recurse Suggestions
a178235
Recurse Suggestions
Post by a178235 »
When I select “Show all files (recursive)”, I would like to be able to sort by folder, or ideally, a multi-level sort, i.e. Folder -> Name. Also, when I select “Start slideshow (recurse)”, I see the file name listed at the top left. Is there a way to disable this? I would also like to suggest that the last image viewed is saved so that it is automatically selected when starting XnView.
