Where in settings can this message be disabled from showing up:
This image contains multiple pages. Please use "Previous page" and "Next page" to navigate between the pages.
Disable 'This image contains multiple pages' message
Re: Disable 'This image contains multiple pages' message
You have 'don't show again' checkbox
c627627
c627627
What exactly changes when you check 'don't show again' checkbox? Is the change made in registry or the program folder? Is the only way to make this change if you happen to have a file which prompts this?
marsh
It uses the following setting:c627627 wrote:What exactly changes when you check 'don't show again' checkbox? Is the change made in registry or the program folder? Is the only way to make this change if you happen to have a file which prompts this?
[Start]
ShowAgain=
Numbers (+/- 1 for multipage?) can be added/subracted according to this topic.
c627627
Thank you.
Can you please tell me where (registry or file - which one? location?) the following information is stored.
[Start]
ShowAgain=
[Start]
ShowAgain=
marsh
The latest "about" dialog shows which settings are in use (beneath the contact information), ex: D:\xnview\xnview.inic627627 wrote: Can you please tell me where (registry or file - which one? location?) the following information is stored.
... along with Options... System integration>Integration>Save options [x] as INI in folder [XnView]
c627627
Very well. I located the xnview.ini. I then saved it elsewhere.
Then when I got the message that 'This image contains multiple pages' I checked the box to never see it again. I then compared the xnview.ini with the old saved one in a compare line by line program and the new one had
ShowAgain=268435423
the old one had
ShowAgain=268435422
It was reduced by one. Is that it? You reduce that wired large number by one?
ShowAgain=268435423
the old one had
ShowAgain=268435422
marsh
Reducing by one hides it for me. Removing setting altogether caused the following number to be created:c627627 wrote: It was reduced by one. Is that it? You reduce that wired large number by one?
=268435455 ...show all(?)
=268435454 ...show all(?), after hiding multipage
=0 ...show none(?)
=1 ...show only(?) multipage
