I have tons of videos...about 4000 files and I have no problem generate thumbnails and store them in cache in version 1.95. But in version 1.96 beta 3, about 3/4 of the way, it stop generating thumbnails and froze up!!!!
So something is wrong with your cache storage.
B3 - froze up when caching video thumbnails.
reptilexcq
Re: B3 - froze up when caching video thumbnails.
If you disable thumbnail cache, you have no problem?
reptilexcq
Correct. Even if you disable thumbnails cache, about 3/4 into the cache, it will says "a problem has occur that cause XnView to shut down."xnview wrote:If you disable thumbnail cache, you have no problem?
Also can you solve this problem also: even in version 1.95. When you have cached the whole entire folder, it takes a while to load up the entire folder. Like whenever you start XnView, it will froze up for 1min to 2min while waiting for it to load the cached thumbnails. I think it should not froze up because the files are already caches and should load up INSTANTLY!
reptilexcq
Also can add this feature:
1. Allow videos to play within thumbnails. In other words, you can press a play button and the video play RIGHT INSIDE the thumbnails, not having to open an external player.
2. Set any frame as thumbnail
Like this program is using, Antares10:
http://www.orbitaldis.com/
Sorry, if you disable thumbnail cache you have the crash? Could you send me your email to send a test version?reptilexcq wrote:Correct. Even if you disable thumbnails cache, about 3/4 into the cache, it will says "a problem has occur that cause XnView to shut down."xnview wrote:If you disable thumbnail cache, you have no problem?
reptilexcq
Yes. Email: <removed>xnview wrote:Sorry, if you disable thumbnail cache you have the crash? Could you send me your email to send a test version?reptilexcq wrote:Correct. Even if you disable thumbnails cache, about 3/4 into the cache, it will says "a problem has occur that cause XnView to shut down."xnview wrote:If you disable thumbnail cache, you have no problem?
<Moderator's note: Mail address has been removed - please see Rules and Guidelines>
Dreamer
Ok, i send you a version...reptilexcq wrote:xnview wrote:Sorry, if you disable thumbnail cache you have the crash? Could you send me your email to send a test version?reptilexcq wrote: Correct. Even if you disable thumbnails cache, about 3/4 into the cache, it will says "a problem has occur that cause XnView to shut down."
