Tools -> Extract Movie Frames for .flc?
Jasper
Post by Jasper »
I'm trying to split a .flc into a bunch of .pngs, but the option to "Extract movie frames..." is greyed out in the Tools menu. I can step through the frames one at a time and save them, so there doesn't seem to be any trouble with the .flc or XnView...
Am I missing something? Is there something else I need to do, or perhaps another way to do it (some sort of commandline option perhaps?)
Thanks in advance,
-Jasper
Re: Tools -> Extract Movie Frames for .flc?
Jasper wrote:I'm trying to split a .flc into a bunch of .pngs, but the option to "Extract movie frames..." is greyed out in the Tools menu. I can step through the frames one at a time and save them, so there doesn't seem to be any trouble with the .flc or XnView...
I'll add FLC soon
Post by Guest »
of course for all FLC extensions (flx,flx,fli,..)
MAAD
Jasper
Post by Jasper »
Thanks for the quick reply! I suspected it was just a bug, but had my fingers crossed. ;-)
Any idea roughly when "soon" is? weeks, months, years? I don't mean to pressure you, it's simply that before too long I'll run out of time and need to hack it myself some other way.
