Colour quality isn't right (images included)
HoldThem
Post by HoldThem »
I've tried lots of settings, it keeps coming out with quite off colours! Any ideas?
Re: Colour quality isn't right (images included)
Perhaps the pdf has ICC profile??
HoldThem
Post by HoldThem »
Thanks for the reply, is there any way with this component to ignore the ICC profile, or will I have to remove it before uploading?
Thanks for your reply
HoldThem wrote:Thanks for the reply, is there any way with this component to ignore the ICC profile, or will I have to remove it before uploading?
The icc profile is not readed on pdf, it's perhaps the problem
