help, I can not convert into the desired format Prompt
thefree
Post by thefree »
nconvert -quiet -colors 2 -c 6 -rmeta -out tiff -o bike-test2.tif bike-test2.gif
info bike-test2.tif
bike-test2.tif : Success
    Format               : TIFF
    Compression          : Uncompressed
    Width                : 453
    Height               : 581
    Components per pixel : 1
    Bits per component   : 4
    Depth                : 4
    # colors             : 16
    Color model          : RGB
    Bytes Per Plane      : 227
    Orientation          : Top Left
    Xdpi                 : 72
    Ydpi                 : 72
    Page(s)              : 1
tiff form must be obtained with such parameters
    Format               : TIFF
    Compression          : CCITT Group 3-2D
    Width                : 1728
    Height               : 1142
    Bits per component   : 1
    Depth                : 1
    # colors             : 2
    Color model          : RGB
    Bytes Per Plane      : 216
    Xdpi                 : 204
    Ydpi                 : 98
    Page(s)              : 1
Please Give me what is missing
Re: help, I can not convert into the desired format Prompt
use -binary dither instead -colors 2
Post by Guest »
 nconvert -binary dither instead -colors 2 -quiet -colors 2 -c 6 -rmeta -out tiff -o bike-test2.tif bike-test2.gif
Bad binary dithering 'dither'
** NCONVERT v5.02 (c) 1991-2008 Pierre-E Gougelet (Aug  4 2008/10:02:41) **
        Version for Linux x86 (X11)  (All rights reserved)
** This is a freeware software (for non commercial use)
Try
 nconvert -binary dither -quiet -c 6 -rmeta -out tiff -o bike-test2.tif bike-test2.gif
