Working with files sorted by folder (path)
mumajs
Post by mumajs »
can you please add sorting by folder (path)? Or add to details column folder (path)?
I have some photos and I use the function "Show All Files" and then I want to sort them by directory (folder, path).....
Useful will be also some content table where will be the list of found folders with images and I will be able to click on the folder and it will show me the images.
Or make the checkbox for the function "show files in subfolder". So when It will be chekced then it will load all files in selected folder and subfolders
Best will be implement grouping, but sorting will be enought for me.
Thank you
mumajs
Post by mumajs »
Any comments? Nobody want this? I think it is not difficult to implement sorting by path.... please.....
volve
Re: Working with files sorted by folder (path)
Post by volve »
+1
I want this very much. It's the only feature I use IrfanView for -ever- but I love XnView! Basically if you use the ratings or categories features of XnView, without "Sort by Path" you end-up looking (in my case at least) at a very jumbled list because the images are all just numeric.
Please, please, please can we have this feature? Hell, I'll PAY for this 1 feature.
(Maybe that's another suggestion: Let people donate money to individual feature suggestions so the ones that are "worth" the most actually get built.)
Thank you for XnView though, it's wonderful even without "Sort by Path"! :D
-volve
