How do I add author name to IPTC?
jaqian
Post by jaqian »
Is it possible to add the author name in XnView to the IPTC? If so, how do I go about it? Cheers.
Sony Alpha α100 (Silver)
Linux Mint 7
Re: How do I add author name to IPTC?
jaqian wrote:Is it possible to add the author name in XnView to the IPTC? If so, how do I go about it? Cheers.
Do you know the IPTC tag ID for this field?
jaqian
Post by jaqian »
I don't but I did a quick Google and I think this is it...
Tag - Name - Description
80 - ByLine - Byline. Photographer, for example "Your Name". 32 Bytes
From here: http://www.vcode.no/resource.nsf/ii2lnug/643.htm
Any help?
Linux Mint 7
So you have ByLine in 'Edit IPTC'
jaqian
Post by jaqian »
Thanks Pierre, sorry about that.
Linux Mint 7
