VB/ASP ActiveX vs. VB modules
Antoine
Post by Antoine »
Just wanted to know what the major differences are in terms of functionality, if any. I know I would rather use the activex but if there are significant things that can't be done with it then will get into the modules instead.
Cheers
Antoine
Re: VB/ASP ActiveX vs. VB modules
Antoine wrote:Just wanted to know what the major differences are in terms of functionality, if any. I know I would rather use the activex but if there are significant things that can't be done with it then will get into the modules instead.
Which feature do you want in the Activex?
