I'm trying to access a Citrix application for work and I'm prompted to download an ica file (launch.ica). I can download the file, but when I try to open/find it, I get an error message "windows can not open this file". Is there a simple free download available that will fix this problem?
PS, I have Windows XP
Thanks,
Randy
opening ica files
See options---
• *.ica (IOCA) is supported at reading only. Please, check :
Options (F12) >> General >>[Operations] >> [×] Display all images file types, that box must be ticked.
Above, Clo has provided the right answer, FAQ Does XnView support graphic format .xyz? might also be of interest.
