Copy/Move to deleted Folder - press 100 times 'Cancel'
brotondi
Post by brotondi »
1. XNView: open a Tree with Folders A and B
2. Explorer: Delete A
3. XNView: Move 100 Files from B to the deleted A (in XNView sometimes still visible)
-> You cannot press "cancel" for the whole operation, instead you must "cancel" every single file...
Workaround 1: Press "Create Folder" (which normally will be possible).
Workaround 2: Kill XNView...
Bruno
Edit: I just tested it in 1.96 (Vista Premium 64): XNView detects every Folder-Deletion. Nice :) ... so better to forgot this minor but
