Sorting files in multipage & slideshow dialog
Post by Guest »
i miss a sorting feature (by type/name/size/path..) in:
1- multipage format dialog.
2- slideshow dialog.
MAAD
Re: Sorting files in multipage & slideshow dialog
Anonymous wrote:i miss a sorting feature (by type/name/size/path..) in:
You have it already. On the file list, you have a popup menu (right click)
crazytb
Post by crazytb »
Hey! Wow! I never would discover that feature! And it works in Linux too!!!
Pierre, please add a simple "label" below the files listbox to tell us this. I think 95% of users do not know about it.
Button "Sort >>"
crazytb wrote:...I think 95% of users do not know about it.
Think it's 99.9% of the XnView users. ;-)
For two reasons it is really very hard to find this hidden functionality:
- Until now, context menus (menus that are opened when right clicking) are provided rarely in XnView.
- Normally, context menus do not contain extra functionality, that means more functionality than available with buttons / menus / ...
So users should be really pointed to the sorting functionality. But I am not sure whether a label is the right thing.
What about a button "Sort >>" that opens the menu when clicking on it? (Similar to the button "Insert >>") in batch rename.
crazytb
Re: Button "Sort >>"
Post by crazytb »
helmut wrote:For two reasons it is really very hard to find this hidden functionality:
And a simple "listbox" commonly does not have a context menu in any application. It does not mean that it is forbidden, but it will be "hidden".
helmut wrote: So users should be really pointed to the sorting functionality. But I am not sure whether a label is the right thing.
Good idea. I said about label only to be the fast and easiest way to "fix" it, but a button would be better.
