[suggestion] strip of images,read height/width from 1st file
herr_k.
Post by herr_k. »
every time i want to make a strip of images, the value is kept.
please add a selection box with the possibility to choose [ ] keep height/width.
i often use a picture and add another one to it, keeping the dimension of the first picture.
i have to figure out the dimension and have to enter the values manually every time i want to get a new strip (maybe you could change this to get the values automatically from the file that is on the top of the file list?).
Troken
Re: [suggestion] strip of images,read height/width from 1st
Post by Troken »
herr_k. wrote:every time i want to make a strip of images, the value is kept.
Good suggestion. I'd like to add the possibility to choose the hight of the image with the smallest height (so that no image will be upscaled and thus interpolated).
