Occasional error when using Ctrl.GetPicture (VB)
NickD
Post by NickD »
I've just recently stumbled across GFLAx and I'm very impressed indeed. Just one problem I'm experiencing is that I occasionally get an error when using Ctrl.GetPicture for no apparent reason. If I unload VB and reload again, usually all is well. Any ideas ?
Regards,
Nick
Re: Occasional error when using Ctrl.GetPicture (VB)
NickD wrote:I've just recently stumbled across GFLAx and I'm very impressed indeed. Just one problem I'm experiencing is that I occasionally get an error when using Ctrl.GetPicture for no apparent reason. If I unload VB and reload again, usually all is well. Any ideas ?
Do you have the problem on same picture? Or is it randomly?
NickD
VB Problem
Post by NickD »
Mmmm... I'm not sure, I'll investigate further. Thanks for your prompt reply, I'll get back to you once I've determined whether it's random or not.
Regards,
Nick
