I need XnView to be able to use x64 codec's like flvsplitter.ax and mp4splitter.ax.
If I install the x86 editions, Windows Explorer won't be able to produce FLV and MP4 thumbnails!
Last time, I checked XnViewMP is still 32-bit isn't it?
Anyway the codec's I'm using are SVN 1004 available here:
http://xvidvideo.ru/
Req. XnView x64 version
ckit
Re: Req. XnView x64 version
Yes, but i will able to build a 64bits versionckit wrote: Last time, I checked XnViewMP is still 32-bit isn't it?
