avi files from virtual dub do not open correctly
wfisch
Post by wfisch »
I have Problems with avi movies after cutting with virtual dub.
The files come either from an CANON Ixus or from an Rollei Compact Camera.
The movies from the cameras open normal with xnview.
When I cut it with virtual dub an save it to an uncompressed avi-file it opens as well.
When I save it to a divx or other compressed avi-file and want to open it with xn-view I get the sound of the movie but the screen black.
After changing the modus "fit in the window" I get the movie. Now Ican change the "fit in the window"-modus without problems.
I don´t know if this is an xnview or an virtualdub problem. Probabbly it has to do with the Codec.
I use virtual dub as its the only programm I found that can turn movie from landscape to portrait.
Thanks for your help. :D
Xnview i´m using now for about 5 years withour problems.
I am using Windows XP, my xnview Version is 1.95.4
virtual dub 1.8.8
