ThanksNConvert v5.30 for Windows/Windows 64bits/Linux/Linux 64bits/MacOS X/FreeBSD/DOS32 LE & OS/2 is available. NConvert can be downloaded on the NConvert download page.
What's new:
and one more:XnView v1.96 (LIBFORMAT v5.30) 23/02/2008:
* NConvert: opacity for watermark - http://newsgroup.xnview.com/viewtopic.php?p=68466
* NConvert win: "-out clipboard" to export into clipboard - http://newsgroup.xnview.com/viewtopic.php?t=16313
* NCONVERT: -icc_in & -icc_out to convert ICC profile
* NConvert: page number for pdf - http://newsgroup.xnview.com/viewtopic.php?p=69498
* NConvert: watermark order - http://newsgroup.xnview.com/viewtopic.php?p=69499
* NConvert: Default extension - http://newsgroup.xnview.com/viewtopic.php?t=16549
* NConvert: Merge_alpha order - http://newsgroup.xnview.com/viewtopic.php?p=69312
The bug with "DOS version reports itself as OS/2" is fixed
The things I had reported about the "resize" and "rotate" functionality and syntax are same as before, though.
