Batch rename using XP-Author works only with pictures
herwigv
Is it possible that the batch rename function works also with word or pdf -files if you want to insert the XP-Author, XP-Comment or XP-Title?
Re: Batch rename using XP-Author works only with pictures
You can use them already...herwigv wrote:Is it possible that the batch rename function works also with word or pdf -files if you want to insert the XP-Author, XP-Comment or XP-Title?
