I'm new to Xnview so sorry if I'm asking a question yet done. I did use the search and read the FAQ but didn't find the answer.
Is there any possibility to view the embedded preview of a DNG file in it's full size and all the modifications in comparison with the original RAW image?
Currently I see only either the fully decoded DNG (which obviously is the original RAW image) or the embedded thumbnail, which itself is very small, for example 570x375, and corresponds obviously also to the original RAW File and doesn't contain any applied modifications.
I set the various options but couldn't find the right combination.
Thanks in advance
Goddert
DNG Preview
Re: DNG Preview
Please send me a sample?
