resize tiff with alpha
rockobello
Post by rockobello »
is there a way to batch resize a tiff and keep the alpha channel? i tried it again and again and always i loose the alpha channel...
Re: resize tiff with alpha
By default alpha is kept, do you use resize or batch/resize?
Post by Guest »
"by default" was the right hint! thank you !
some time ago i changed a option to "ignore alpha". i thought it would only affect the viewing.
my fault !
