Moving keywords around in defined keyword list?
knight666
Post by knight666 »
I'm new to XnView, and I'm using it to categorize my wallpaper collection. I'm adding IPTC tags to every image in there so Vista can more easily search it, based on keywords.
The problem I have is that I can add keywords to the keyword list, but then I can no longer move them around!
So, for instance, I have this list:
"wallpaper
space
enterprise
bear
minimal
art"
"minimal" is a keyword that is much more common than "space", so I want to move it just under wallpaper, except I can't!
There also doesn't seem to be a way to export the keyword list to a readable format. :S
Is there any way to do this with XnView?
Thanks in advance.
Re: Moving keywords around in defined keyword list?
It's stored in iptc.def
knight666
Post by knight666 »
There is no iptc.def on C:\ or on F:\ (where XnView is installed) or on H:\ (where the pictures are).
you should have it if you add keywords in default, the .def is in the user folder
