I have some asp script calling the .crop command.
I'm using it as ctrl.crop x, y, width, height but it isn't cropping my image.
Can someone help me with the syntax?
I missed the reference to the .dll methods and properties syntax in the help file, or maybe it isn't there. Is it available anywhere?
Crop in .asp
b.e.wilson
I just found a french version of the list I am after here: http://www.cwm.ca/SupportComp/GflAx_Fr.html
Bablefish did a poor translation into english, a usable one, at least.
b.e.wilson
b.e.wilson
The help file I found was the GflAx-help.chm file at the top of the GflAxlite.zip file available at the link below. Oddly it is not installed by the regular GflAx.exe installer.
http://perso.wanadoo.fr/pierre.g/xnview ... flwin.html
Here is the french help file on the web: http://www.cwm.ca/SupportComp/GflAx_Fr.html
Graeme
Help File
Hi, Glad you could find a help file with more than the basics! Could you or someone please upload the file somewhere as the one I find in any of the packages has no useful information for working with GflAx from ASP, just how to register it in IIS and what formats are supported. The only other "help" I can find is snippets on this forum.b.e.wilson wrote:The help file I found was the GflAx-help.chm file at the top of the GflAxlite.zip file available at the link below. Oddly it is not installed by the regular GflAx.exe installer.
Thanks in advance.
- Graeme
