gflSetIPTCValue - Delphi
kurka666
Post by kurka666 »
I have just downloaded the GFL SDK for use with Delphi, but it seems the gflSetIPTCValue function (amongst others) are not available to Delpih. Is this correct, and if so, when will it be available.
I intended to use the GFL SDK mainly for updating IPTC-information
Re: gflSetIPTCValue - Delphi
kurka666 wrote:I have just downloaded the GFL SDK for use with Delphi, but it seems the gflSetIPTCValue function (amongst others) are not available to Delpih. Is this correct, and if so, when will it be available.
Yes, i have not updated the delphi wrapper. Don't when because i'm not expert with Delphi ;-)
Post by Guest »
oh - could there be anyone else here at the forum that can do this, or that have already done so?
Eric__38
can this help U ?
Post by Eric__38 »
hi, i'm a Delphi programmer too.
try to update the libgfl.pas like this :
1/add in interface the lines (AFTER DECLARATION OF PGFL_IPTC_DATA) :
function gflSetIPTCValue(iptc_data: PGFL_IPTC_DATA; id: GFL_UINT32; const filename: PChar): GFL_ERROR; stdcall;
function gflNewIPTC: PGFL_IPTC_DATA; stdcall;
2/add in IMPLEMENTATION (AFTER COMMENT '// functions in LibGflxxx.dll') the lines :
function gflSetIPTCValue; external GflDLL;
function gflNewIPTC: PGFL_IPTC_DATA; external GflDLL;
sample of code :
procedure TForm1.Button1Click(Sender: TObject);
var iptc_data: PGFL_IPTC_DATA;
begin
  iptc_data := gflNewIPTC;
  ///fill iptc_data
  gflSetIPTCValue(iptc_data, 0, 'c:\0.jpg');
  gflFreeIPTC(iptc_data);
end;
NOT TESTED but compilation is ok.
bye, bye
Eric
kurka666
Re: can this help U ?
Post by kurka666 »
Thank you very much. I'll give that a try tomorrow!
Let me know if you have any Delphi-samples to share! :-)
