is it possible to change the name of the color tags (e.g. if instead of "work" I'd like to use "final")?
Thanks for the great program!
Frank
Change Name of Color Tags
Yes you can change them by manually editing your settings (xnview.ini or registry).
To change the labels add a new option called ColorLabel-# (# = 0-5) in the Browser section of your settings.
In your case to change the "Work" label with "Final" add ColorLabel-2=Final in the Browser section.
Re: Change Name of Color Tags
Just to correct it for folks that try this out: The # ranges from 0-4, where 0 is red and 4 is purple.
