Wrong image displayed in preview
Dreamer
Post by Dreamer »
- enable the parent folder [..] item for thumbnails view
- enter the folder in thumbnails (or thumb. & label) view
- select all files
= no file is displayed in preview (I'm not sure if this is a bug, but the first, or last item should be displayed) :bug: #1 (?)
- select the first image
- no problem, the first image is displayed in the preview
- select all files
- select the second image
= last image is displayed in preview :bug: #2
XnView 1.96, Win Vista SP1.
Dreamer
ckit
Post by ckit »
Confirmed both issues!
Different with XP
:arrow: Dreamer
:) Hello !
• I can confirm for #1. However, I don't think it's a bug, since the first item is the parent folder itself, not an image file… Image
• I cannot confirm for #2, here under XP-Pro SP1, the second image is displayed as it should.
:mrgreen: KR
ckit
Re: Different with XP
Post by ckit »
Clo wrote::arrow: Dreamer
:) Hello !
:mrgreen: KR
Good, that tells me it's a Vista-OS issue!
obelisk
Post by obelisk »
confirm this in XP too
Watch it---
:arrow: obelisk
:) Hello !
• Please, which XP are you using ? You may verify that the bug doesn't occur here by viewing that VIDEO…
:mrgreen: KR
Dreamer
Post by Dreamer »
OK, so I can't reproduce #2 sometimes, don't know why, just try to enter another folder until you will be able to reproduce. I can reproduce it always in some folders, sometimes in others and never in one folder. :?
BTW - when you select all, then select any picture, the correct picture is displayed, then select all, select any picture, the last picture is displayed, then again select all, then select any picture, the correct picture is displayed, then select all, select any picture, the last picture is displayed...
Dreamer
