Dark print preview
comitor
Dark print preview
Post by comitor »
Hello
When I print an image in Xnview I have a very dark print preview and when I confirm the printjob, the output from the printer is a ddark image. In the imageviewer from xnview, the image looks fine, so it is only in the print preview.
Can anyone help me?
Thx!!
Rohabu
Re: Dark print preview
Post by Rohabu »
I had the same problem as comitor had in March 2009.
For future use here's the solution:
In the print dialog you have an up-down-control to set the Gamma Value for the picture...set this to 0,0 and the picture should look normal in the preview pane again (also on the printouts)
could you send me a sample that you try to print?
