after copy and paste I can't see new file in directory
guelu
Post by guelu »
I've a problem with copy and paste. If I copy a file from one directory to another, I can't see this file in the destination-directory. I first must close this directory, then open once more and then I see the file. It's not a great bug, but it's disturbing.
Please help me if you can. Thanks
guelu
Re: after copy and paste I can't see new file in directory
Do you use Filter by>Custom?
guelu
Post by guelu »
no, I use "all"
guelu wrote:no, I use "all"
To copy/paste, you use Edit/Copy, change folder and Edit/Paste?
guelu
Post by guelu »
Yes, I go on the right window mark a picture and select copy, then I select on the left side another directory click in the right window and select paste and then no change is to see. Now I must change into another directory and come back to the directory where I paste the picture and then I can see it.
By the way, the computers of my women and my son have the same problem.
Anyhow, be sure I find XnView great!
Greetings
guelu
I can't reproduce this bug. Do you copy a .jpg file? If you copy & paste in the same folder?
Which version of XnView do you use? Which OS (XP, Vista, ...)?
guelu
Post by guelu »
Yes, I copy .jpg-files and it is incurious if the destination-directory is the same as the source or not. It's always to go the same detour.
I use XP pro 32 Bit and XnView Version 1.96 (Feb 24.2009) Libformat Version 5.30
guelu
Post by guelu »
I made a test with vista 64-Bit and there is the same problem.
ckit
Post by ckit »
Have you got "Allow pasting to selected subfolder" enabled in Options?
guelu wrote:I made a test with vista 64-Bit and there is the same problem.
And with a clean .ini?
guelu
Post by guelu »
Yes, the option is marked
I had installed it on a new installed system (second operation system on my PC)
Today I will test it with kubuntu 64-Bit (third operating system on my PC). I'll tell you the result.
guelu
Post by guelu »
Sorry I can't test XnView with kubuntu yet, cause I've a problem to install it, that's a kubuntu-problem,
but the problem with XnView in XP and Vista is more important for me.
guelu wrote:but the problem with XnView in XP and Vista is more important for me.
Could you try in a folder with 1 file, and try to copy it on the same folder
guelu
Post by guelu »
As you asked me to try with a folder with one file and copy this into the same folder, I made a testfolder on my desktop and tried it.
XnView worked proper with this folder. After trying something I could isolate problem - XnView works proper with all local folders, folders on other extern hd's (usb) and also with a testfolder on another pc in my LAN.
The problem is only with my network-harddisk (all my digital fotos are archived there). It is an iomega MDHD500N for homenetworking.
If I copy outside of XnView, paradoxically the copy and paste on this hd works correct.
